Re: Tomos A3 no spark (points ignition)
Don Ohio /
Okay,one thing that you need to do is check that the wire that goes to the kill switch is NOT grounded.That happens a lot.......the switch lets the wire ground out even when it is in `run'. Trace that wire back to make sure it hasn't grounded on its way to the kill switch. don-ohio (:^)
