Re: Tomos A3 no spark (points ignition)
Patrick Keaton /
The coil picture was taken in not enough light,so it can not been seen if it is set up right or not.The other picture with all the wires was taken with not enough light and is out of focus,so it is hard to tell what is what.Grounding the brake light wires might be a problem,so try connecting them together or leaving them a part.Did you check the breaker points with an ohm meter before installing. I seen at least one new breaker points have a haze on the contacts that had to be filled of with a disposable finger nail file.
