2011 tomos a55 electrical problems
richard george /
I need help on trying to figure it out new battery still no lights blinkers horn starter are all dead I checked the fuse is good what can be the problem
Re: 2011 tomos a55 electrical problems
Voltage regulator? You sure the fuse has current going thru it? Check to see. don-ohio (:^)
richard george /
that's what I thought but was not sure about the problem it could be 1 of the 2 relays
Get a meter and start diggin :/
I had the same problem, check your speedometer light bulb, mine was grounding out killing all the power. Just remove the leads and tape them off. I'm quite sure that is the problem.
My light hasn't worked for a long time,and that would have to be a grounded hot lead to the speedo light to cause that. don-ohio (:^)
