Re: 1980 nc50 electrical setup
geoff ballou /
What you are told about the battery is correct. Do you have the right battery and fuse in your scoot and is it correctly hooked up? Then check to make sure you don't have a ground issue.
I had to pull my wiring harness and check everything to the wiring diagram in the manual.
One last point: test wiring with cheap bulbs.
