Yamaha Towny-removing oil tank.
rick partsunknown /
I have decided to reconnect the oil pump on a Towny I recently purchased. This is the last bit of refurbishing I need to do.
I want to get the oil tank out so that I can clean it thoroughly. Any help with the following questions is greatly appreciated.
1. In general terms, what should I disconnect, in order, to get the tank out? Answer does not have to be perfectly detailed; anything here would be helpful.
2. When I get the oil system clean and pumping, I will attempt to calibrate while I am still running premixed oil in my gas. Any advice or tricks to keep in mind calibrating, and being sure that pump is working properly?
Thanks.
Rick
Re: Yamaha Towny-removing oil tank.
rick partsunknown /
Thanks. I guess it is time to read the manuals.
It will save you a lot of headache.
