golden bullet many issues
Wesley Burson /
Just got a running golden bullet today. It runs but has no breaks, no headlight or lights in general, and it does not idle. I tried setting up the breaks, but they will not work. Any advice would be great!
Re: golden bullet many issues
I have no idea about the electrics, maybe they are on the wiki. For the brakes: are the wheels locked? Or do they rotate? Also try adjusting the brake cable. For the idling issue, does it idle for a little or nothing at all? Try adjusting the air/fuel screw, screwed all the way in for a very high idle
Wesley Burson /
The breaks are weak when fully engaged, idle has not been messed with
Try opening up the brakes and sanding them a bit and then clean them off with a brake cleaner, while you're at it, you should grease the wheel bearings and brake pad springs, and yea the idle screw should help
♣Slew Foot♣ /
usually it wouldn't even start when the wiring is off.
