Za50 dies after WOT speed run.
Antman Sandersan /
All is good at first then after about a 5min wot speed run, it just dies. Won't restart until it cools down.
Za50
Treats 50cc kit
12mm bing
72 jet (I know, that's kinda big for a 50cc, but same thin happens at 60-64)
Circuit pipe.
Times at 1.5mm btdc
Is this a condenser issue? I'm guessing it gets hot or the higher rpms freak it out?
Doesn't seem to be starved of fuel.
Re: Za50 dies after WOT speed run.
Probably Fred /
Ya your overheating and possible top end damage it at 19° before top dead center 1.5=19°Btdc
Time @.8°or 14° before top dead center to start and if you run cool below 400°F on your head temp gauge then you could add more timing but I doubt you run cool enough ever at 19° before top dead center or 1.5 mm.
This regard the Za50 timing on chart and time the same as a e50 that timing is for stock cylinders not kits. I don't know why a za50 is listed with higher timing anyway. Mine run fine even a little below 14° on the flywheel.
Just another wrong puch thing in wiki like hardwiring, running .05mm za50 shims, full advance timing, using a piston stop, no mention of magnum ll having spoke wheels saying only #4 cylinder is a 1 hp restricted when every number cylinder including a hi torque can have a restrictor in it amongst other erroneous information I guess.
72 jet is fine if 222 atomizer even for a 12mm bing.
Make sure you have perfect gas flow. Don't run without a temp gauge unless you like buying new kits
Antman Sandersan /
Damn, that chart is so misleading.
Adjusted the timing to 14deg. A little more sluggish off the line, but picks up soon after.
Put a temp gauge on, hottest it got was 340.
Lots of stop and go traffic right now, but got it to wot on a short run then stalled at stop sign. Started up again, maybe 3min later. Retard more?
