Re: 1978 puch maxi mk2 re jeting
Probably Fred /
If it runs good with the 62 jet put holes in the slide up high in the bore just for more air correcting the mix only at idle so when the throttle is opened they get blocked.
Start small 3/32 in then make bigger if needed(because return spring may block some) until bike idles good search other posts of mine for more info
