Moby CDI, regulator and lights weirdness
scott middleton /
I have the Le Partie CDI and Treats regulator (this one) installed on my Moby, and whenever I hit the brakes, the headlight dims significantly. Tried it with a different headlight, (thought maybe the one I was using was too high wattage) same result. I am using the same tail light bulb in my points moby, and it works fine. Checked the wiring path for shorts, etc. all fine. The brake lights switches are correct (NO), and wired correctly (power from reg > switches > to brake lights). Any ideas? (edited)
Re: Moby CDI, regulator and lights weirdness
have you tried a lower wattage tail light/brake light bulb in it?
scott middleton /
not yet. all the bulbs I have are the same right now. it's the same bulb that's in my points moby. the CDI has to have more power than the old school stator.
simon thokaar /
id love to chime in since i just installed the le partie cdi myself, unfortunately treats sent me this instead of a regulator so i dont have lights hooked up yet.
