Cracing upper fork plate
Found crack on upper fork plate, will welding it be reliable in long run?
(edited)
Re: Cracing upper fork plate
Brent Bublitz /
Better off digging up a new plate if you can. You could weld it, but its a little thin to hold up well.
That looks scary to me... If you must weld it, see if you can bend a piece of steel rod to fit in the back/bottom for strength.
Pete
That top plate is easily replaceable, a shouldn't cost you much. Otherwise drill the end of the crack and weld it.
One i have is prior 1980 its rare, newer one from 1980+ is different.
See that piece that connects hand to plate i have old design (forgot to mention its cracking too).
Can someone confirm if all i need to fit newer design fork plate to old frame is this piece that holds wheel or need more work?
(edited)
Here's where hand bar connector cracked on driver side.
(edited)
So i should learn it hard way or someone knows if newer upper fork plate fits old fork?
Brent Bublitz /
Learn the hard way. odds are it will fit.
I would weld it. As long as you're going 30 it should be fine.
^depends on your welds too.
I would absolutely weld it. and i'm not very good. I would also without hesitation get a replacement newstyle one just to know if it fit and also have a backup.
