Another Kinetic wiring post...
Are Kinetic TFRs the kind that need everything to be working and in place in order to get spark. Like if the brake light bulb is blown, I won't be able to get any spark?
I also don't have blinkers on my bike, do I need those for spark?
I'm thinking my igntion switch is bad since that is a typical problem with these... If I replace the switch would this be a good one to go with or would you have other recommendations:
https://www.treatland.tv/2-terminal-ignition-switch-with-key-p/wps-ignition-switch-2term.htm
Thanks for the help.
Re: Another Kinetic wiring post...
Anybody?
I don't think so, the lighting is totally separate, maybe this will help: http://www.mopedarmy.com/wiki/Category:Vespa/Kinetic
