Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?
Princess Rapunzel /
I had a problem, replaced my low-compression E50 hi-torque top end with a used stock 50 kit, still not kicking over. I was super confused, I thought I had fuel, my plug was getting wet, seemingly good compression (didn't test it) and my spark plug, althought a little fouled, had seemingly good spark. Bought another BH6S at Orielly's, put it in and blam, fired right up. My E50 seems to be a bit picky with it's plugs, sometimes it'll work on one, other times not. Try a brand new BH6, it might fix your problem if you'v been using old plugs.
  E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Topic by: Adam D Adam D 06/19/14 09:57AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 10:17AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Mike A Mike A 06/19/14 11:44AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Micheal H. Micheal H. 06/19/14 11:52AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Probably Fred Probably Fred 06/19/14 12:29PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:53PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:52PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 01:13PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 01:55PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 02:28PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 02:41PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 03:07PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Princess Rapunzel Princess Rapunzel 06/19/14 03:00PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/20/14 09:13AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/20/14 12:06PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 06/20/14 02:10PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: James O'Bryan James O'Bryan 06/20/14 02:59PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/25/14 04:12PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Double Trouble Dan Double Trouble Dan 06/25/14 06:06PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Mars   Mars   06/19/14 12:10PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:54PM
