Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?
Adam D /
I did actually see the spark. Could the plug still be shot in some way even though it appears to be functional? I'll pick one up and test this...
Carb is spotless. the float floats, float needle is good, float height is good.
  E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Topic by: Adam D Adam D 06/19/14 09:57AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 10:17AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Mike A Mike A 06/19/14 11:44AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Micheal H. Micheal H. 06/19/14 11:52AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Probably Fred Probably Fred 06/19/14 12:29PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:53PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:52PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 01:13PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 01:55PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 02:28PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 02:41PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 03:07PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Princess Rapunzel Princess Rapunzel 06/19/14 03:00PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/20/14 09:13AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/20/14 12:06PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 06/20/14 02:10PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: James O'Bryan James O'Bryan 06/20/14 02:59PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/25/14 04:12PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Double Trouble Dan Double Trouble Dan 06/25/14 06:06PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Mars   Mars   06/19/14 12:10PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:54PM
