Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?
Probably Fred /
Micheal H. Wrote:
> 90 psi is too low. Check base, head gaskets and
> piston and ring.
90 is fine
The psi could be more then that especially if your Psi gauge has a hose
Some puch engines (1-1.5 hp with thick head gaskets) when new barely made 90 psi
  E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Topic by: Adam D Adam D 06/19/14 09:57AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 10:17AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Mike A Mike A 06/19/14 11:44AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Micheal H. Micheal H. 06/19/14 11:52AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Probably Fred Probably Fred 06/19/14 12:29PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:53PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:52PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 01:13PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 01:55PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 02:28PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 02:41PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/19/14 03:07PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Princess Rapunzel Princess Rapunzel 06/19/14 03:00PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/20/14 09:13AM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Marc Friedman Marc Friedman 06/20/14 12:06PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Luke “Funkenet” Hosfield Luke “Funkenet” Hosfield 06/20/14 02:10PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: James O'Bryan James O'Bryan 06/20/14 02:59PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/25/14 04:12PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Double Trouble Dan Double Trouble Dan 06/25/14 06:06PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Mars   Mars   06/19/14 12:10PM
  Re: E50: Rebuilt engine/carb. Have spark, gas, compression, no air leaks. Won't start. What else can go wrong?Re: Adam D Adam D 06/19/14 12:54PM
