Trac clipper float needle
I need a replacement needle for my trac clipper. it is a 1987 and has the mikuni carb. I looked on treats they said they didnt have one. does anyone have any idea where i could get one of these?
thanks in advance!
Re: Trac clipper float needle
Morris the Moose /
Can anyone help me?!
yeah , you can probly get it on ebay . Search : mikuni needle valve
Morris the Moose /
not on ebay
Morris the Moose /
can anyone help? PLEASE!
Morris the Moose /
oof. um, it's probably really similar to some other needle. best bet is to either wing it and get a similar looking one from a similar carb (like try a mik vm float). something same era, same size range, same manufacturer of carb s likely gonna be the same float needle.
OR just replace the whole carb with something else less rare.
Totally wingin it here but this'd probably work. compare to your stuffs
http://www.ebay.com/itm/CARBURETOR-CARB-REBUILD-KIT-MAIN-PILOT-JET-NEEDLE-CLIP-GASKET-SPRING-MIKUNI-VM12-/150935840880
Morris the Moose /
Thanks for the help! that looks about right. However, if it is going to cost that much I might want to just upgrade the carb...
