replacing maxi wheel bearings
So, luckily when my rear wheel bearings failed on me, I didn't wipe out down the hill and eat road. Unfortunately, I can't find much for resources on maxi wheel bearing specs. I believe the 28mm sealed bearings available on 1977mopeds will be sufficient, but the stock bearings aren't sealed.
http://www.1977mopeds.com/puch-sealed-wheel-bearing.html
I'm replacing them all at once. Do I need 3 or 4 sets of bearings total?
Any input to confirm or correct my observations is appreciated.
Thanks for the feedback
Re: replacing maxi wheel bearings
most likely it's just the rear...you will need 2 bearings a 12mm axle and a spacer....you will have better luck at Treats.....
You can probably even get the bearings locally, but you'll have to order the shim stock, axle, spacer, etc.
http://www.mopedarmy.com/wiki/Sealed_bearing_conversion
