Re: Blasting home from work and suddenly stopped running (E50)
John Moore /
Ok bro i believe you like i said before, here's the manual start on
page31 fig 24
http://projectmopedmanual.info/Manuals/Puch/Sears-Free-Spirit-manual.pdf
The YouTube link is how to time it if it tests ok with a multi meter and it set right then the next thing down the line is the coil, if that tests ok then test the wires to the plug, then test the gap in the plug. Then your good to go unless you got gas problems then you would go to you carb.
All this is confirmed on page 31 to 99
