Re: Blasting home from work and suddenly stopped running (E50)
Probably Fred /
Stock ignitions are bullet proof but If your not timed low(14-15degrees before top dead center)check compression you may have seized.
Check spark?
Check fuel flow
check compression and if low you may want to inspect the top end piston and cylinder especially on the bottom area
