What is the best way to repair dents in gas tank before powdercoat?
I want to get my tank powder coated but I have two small dings. What is the best way to repair these dings? They are hard to reach from inside the tank so I think I might try to fill them with silver solder or brass braze and then sand them down. Any advice?
Re: What is the best way to repair dents in gas tank before powdercoat?
I have used jb weld as a body filler and it allows powder to stick. No heat necessary. (edited)
jaime diaz /
Was the jb weld spot discolored?
Nope I didn't have any problems I used the original if that helps along with a solid color. what color are you doing? maybe someone else will chime in on this (edited)
jaime diaz /
Ok. I was doing some research and the jb weld works well with solid colors but not with metal flake. I think I might try epo-strong which was developed by a well known powder coat supplier.
what color you powder coating?
george boardway /
pull the dent with a spitsnagel works for me most good body shops have one
jaime diaz /
I haven't decided on the colors yet. Too many to choose from....
Brent Bublitz /
Depending on where the dent is...
