Glenn Kuehn Wrote:
> measure the pin from the float to the pointy end,
> this is adjustable.
> post it here in mm.
> depending where it is, you can enrichen by sliding
> the float towards the point a mm (maybe) pending
> feedback from others.
> getting +10 mph by derestricting the airbox is
> nearly unbelieveable.
> otherwise, just put a tab of tape partly over the
> hole you made, regulate it.
If he was running rich and 4 stroking at anything above half throttle, a 10mph gain is totally believable. I see that with my bikes all the time. Always start rich and work to lean. As soon as you hit that point where it wont 4 stroke at WOT, she takes off. I'm seeing a 3-4mph difference in one bike now with just a one-jet size change.
