Re: NU50 Ran around the block too lean
N Greenup /
Judging by the look and size I think its http://www.treatland.tv/honda-hobbit-pa50-extremo-44mm-60-2cc-p/hobbit-44mm-kit.htm
Do you think the cylinder is too scratched up to be used? If not then I suppose I can just get the piston https://www.treatland.tv/honda-stocko-shocko-44mm-replacement-piston-p/hobbit-stocko-shocko-piston.htm
