Re: Kinetic Woodruff key?
george boardway /
I had the same thing happen yes it was the key but the mag was shot the hole wablled out larry sold me a new mag a vespa key fits I went to tighten the clutch nut and the crank broke off so I replaced the crank the kinetic mag fly wheel again the slot wobbled out treat got me a pinaso mag flywheel and it fixed it the center hub is steel larry had a late TRF riveted flywheel the center is steel not pot metal that's the one you want if larrys out of business try bill web at zippy moped
