Re: Kinetic Woodruff key?
LYNN GARNER /
I agree with Macilius. I had this exact same issue on another two stroke, and the crank nut had loosened, screwing the timing completely by shearing the woodruff key. Engine removal is simple...two nuts and three bolts along with airbox and carb and exhaust.
Larry at Cosmo in Pennsylvania has the correct woodruff key if needed. His number is 215-237-0974.
