Kinetic Woodruff key?
Scott ... /
A couple of weeks ago I bought a slightly used totally stock 2005 TFR, with low miles, it ran OK but I had to adjust mixture screw almost all the way out to run, it finally got to the point where it would try to start up, but wouldn't run. Right before this point it was really starting to backfire. I took carb off to clean, and it had a 41 main jet so up jetted to a 48, assuming it was way too lean. No air leaks anywhere, nice blue spark, great gas flow, and good compression, I'm at a loss, could it be a sheared woodruff key?
