timothy rendall Wrote:
> Hello I had the same problem on my mad maxi I
> ended up rewiring the whole ped including a new
> switch.
> I use 6v 18/18 wat bulb at the front and a 12v 4v
> bulb in the rear.
> This has been tried and tested now for over a year
> as i use the ped to got to work in all wether. I
> do how ever always have a spare bulbs just in
> case, you never know!
> The high volt read bulb will act as a resistor and
> put more current though the front bulb so to stop
> the front blowing you will need a higher watt bulb
> up front.
> Also when switching from high to low, there will
> be a over surge to the rear bulb
> The rear bulb is always on when the lights are on
> but the front will momentarily
> be without power when switching, this will in turn
> give the all the lighting power to the rear bulb!
> that's about 17watts !
> I found that even with the 12v rear bulb it would
> blow. It was only when i did the rewire and new
> switch it stopped blowing the 12v bulb.
> It still blows the 6v ones even now.
> I hope all this helps :)
Probably 2 wire or 5 wire ^ stator
6 wire three phase system most times bulbs last a long time
Sometimes the taillight coil (10w) puts out a little more juice and a 15w bulb is
Needed
