removing 45 year old fork seals
finally getting around to rebuilding my k10 forks, unfortunately the fork seals are coming out in little shreds instead of 1 solid piece. got most of it out except the outer edge of the seal, i don't want to scrape too much and risk damage to the outer sealing surface, got any tips? is there something i can soak the "fork boss" in that will help remove the rubber without damaging the chrome?
Re: removing 45 year old fork seals
Yea I doing kx 80 that were abused. Everything is a mess good luck.
Propane torch. Just a little heat will let it loose it's grip. Heat the outer edge of the fork, not the seal. Use wood or a piece of hard plastic to dig it out.
I just ran into this problem myself. First i had to tear all the rubber out of the seal. I placed the fork boss on a rubber surface (they dent easily) and used a length of pipe and a mallet to tap the metal part of the seal out of the boss. Those suckers do not want to come out without a fight. (edited)
