Re: '78 Honda Express NC50 : Modified : Engine Dies
Quick update all on my honda express noped ...
- I checked the gas cap and ensured that when in "OPEN" state air would easily travel through the pin-sized hole in cap. All good.
- I DID found a very poor connection that was soddered on the Ignition Coil (Spark Coil), green wire I believe. I removed connection, re-stripped wire, and crimped it back with a good solid connector.
- I DID replace the stock Petcock with a newer one, because the old one was leaking fuel. In an effort to get the old petcock to stop leaking I may have disturbed the flow of gas to engine. This could go along with the theories others mentioned about not enough fuel.
I will run some tests this weekend to see if that did the trick.
Thanks for the suggestions, and keep them coming.
-=JFK=-
  '78 Honda Express NC50 : Modified : Engine DiesTopic by: -=JFK =- -=JFK =- 03/29/14 04:01PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Don Ohio Don Ohio 03/29/14 04:16PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Don Ohio Don Ohio 03/29/14 05:19PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Andrew Squiggman Andrew Squiggman 03/29/14 05:59PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 03/29/14 09:40PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Don Ohio Don Ohio 03/29/14 09:48PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Sir Clip Sir Clip 03/29/14 11:41PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 04/01/14 06:34AM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 04/01/14 06:31AM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Jerry Mansfield Jerry Mansfield 04/22/14 02:04PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 04/04/14 04:25PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Brent Bublitz Brent Bublitz 04/05/14 11:12AM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 04/07/14 09:08AM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Brent Bublitz Brent Bublitz 04/05/14 11:15AM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: joey johnson joey johnson 04/05/14 10:58PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 04/06/14 07:11AM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Overpriced Parts Overpriced Parts 04/06/14 01:15PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 04/07/14 05:49AM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 04/20/14 08:46PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Ryan . Ryan . 04/20/14 09:20PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: joe muncey joe muncey 04/24/14 06:39PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: -=JFK =- -=JFK =- 09/22/14 04:15PM
  Re: '78 Honda Express NC50 : Modified : Engine DiesRe: Dirty30 Dillon Dirty30 Dillon 09/22/14 04:46PM
