Re: Garelli NOI 2 speed - Wheel not turning backwards
live ɘvil /
> Josh G Wrote:
> I'm working through a similar issue with my VIP engine. I've tried
> shimming it a few different ways and have had it where the wheel will
> spin backwards without engaging the motor -but only with the crank nut
> relatively loose. I've read that the rubber clutches will swell in
> detergent oil, but I've also read that running the motor for a while
> will 'loosen' the tolerances between the first speed clutch and the
> starting plate / clutch drum.
> Does anyone have any definitive experience with handling this issue?
> Thanks in advance!
Its actually turning the motor over? Moving the piston?
  Garelli NOI 2 speed - Wheel not turning backwardsTopic by: Daniel M Daniel M 10/26/13 03:24PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/26/13 04:01PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Harry Crank Harry Crank 10/26/13 07:36PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 10/29/13 10:46PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/30/13 02:14PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 10/30/13 02:59PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/17/13 10:22PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/30/13 06:27PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: micah aguas micah aguas 11/02/13 06:14PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/20/13 09:34PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 11/20/13 09:45PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/20/13 11:18PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 11/21/13 09:16PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/21/13 11:54PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/21/13 11:55PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/02/19 01:25PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/26/19 12:11AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Sean Colvin Sean Colvin 07/28/19 11:28AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Still Ill Still Ill 09/04/19 09:55AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 12:51PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel '' Daniel '' 04/08/19 03:17PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 04:47PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Stephen Simmons Stephen Simmons 04/08/19 08:07PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 09:02PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Stephen Simmons Stephen Simmons 04/08/19 09:18PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 07/25/19 01:23PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Barry (Bob) Brown Barry (Bob) Brown 07/31/19 08:23PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 07/29/19 02:37PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Sean Colvin Sean Colvin 07/31/19 09:51AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/31/19 04:02PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/31/19 08:06PM
