Re: Garelli NOI 2 speed - Wheel not turning backwards
Declan g /
the second diagram didn't post but I have another diagram that shows two of the spacers that go between gear 1 and two and fit into the slots on the freewheel.
Daniel M.-Good news, I fixed mine tonight-thanks to all that helped. My problem sounds exactly like what you described original, I used some thin shims from a vespa wheel and was able to play with the shimming on the clutch bell until it functioned properly. Now my motor can spin separate from the drive gear and rear wheel until my clutch grabs and I can roll my bike backwards like it should. sort of wonder if using air tools if you can over tighten the nut that holds the clutch side on too? Anyway get some shims and play with it until it does what it should.
  Garelli NOI 2 speed - Wheel not turning backwardsTopic by: Daniel M Daniel M 10/26/13 03:24PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/26/13 04:01PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Harry Crank Harry Crank 10/26/13 07:36PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 10/29/13 10:46PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/30/13 02:14PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 10/30/13 02:59PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/17/13 10:22PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/30/13 06:27PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: micah aguas micah aguas 11/02/13 06:14PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/20/13 09:34PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 11/20/13 09:45PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/20/13 11:18PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 11/21/13 09:16PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/21/13 11:54PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/21/13 11:55PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/02/19 01:25PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/26/19 12:11AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Sean Colvin Sean Colvin 07/28/19 11:28AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Still Ill Still Ill 09/04/19 09:55AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 12:51PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel '' Daniel '' 04/08/19 03:17PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 04:47PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Stephen Simmons Stephen Simmons 04/08/19 08:07PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 09:02PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Stephen Simmons Stephen Simmons 04/08/19 09:18PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 07/25/19 01:23PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Barry (Bob) Brown Barry (Bob) Brown 07/31/19 08:23PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 07/29/19 02:37PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Sean Colvin Sean Colvin 07/31/19 09:51AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/31/19 04:02PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/31/19 08:06PM
