Re: Garelli NOI 2 speed - Wheel not turning backwards
Brian Solex /
I would have to suspect something with spacer 24 or washer 27.
Make sure both are present and that you did not mix them up.
On the one-speed, the washer has a round side and a flat side, and it makes a difference which side faces in/out. (flat towards center of engine.) I would think that the two-speed might be similar.
The nut has to be torqued to about 200 inch pounds...(168 - 224 inch pounds?)...best to use a torque wrench here.
Make sure the rubber nubs and disc are facing the correct direction..."rubber ends should face towards the outer side of the engine and the thicker lined face of the disc towards the inner side of the engine."(edited)
  Garelli NOI 2 speed - Wheel not turning backwardsTopic by: Daniel M Daniel M 10/26/13 03:24PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/26/13 04:01PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Harry Crank Harry Crank 10/26/13 07:36PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 10/29/13 10:46PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/30/13 02:14PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 10/30/13 02:59PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/17/13 10:22PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/30/13 06:27PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: micah aguas micah aguas 11/02/13 06:14PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/20/13 09:34PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 11/20/13 09:45PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/20/13 11:18PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 11/21/13 09:16PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/21/13 11:54PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/21/13 11:55PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/02/19 01:25PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/26/19 12:11AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Sean Colvin Sean Colvin 07/28/19 11:28AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Still Ill Still Ill 09/04/19 09:55AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 12:51PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel '' Daniel '' 04/08/19 03:17PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 04:47PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Stephen Simmons Stephen Simmons 04/08/19 08:07PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 09:02PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Stephen Simmons Stephen Simmons 04/08/19 09:18PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 07/25/19 01:23PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Barry (Bob) Brown Barry (Bob) Brown 07/31/19 08:23PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 07/29/19 02:37PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Sean Colvin Sean Colvin 07/31/19 09:51AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/31/19 04:02PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/31/19 08:06PM
