Re: Garelli NOI 2 speed - Wheel not turning backwards
Daniel M /
Guys,
Thanks for the replies.
"After you install the freewheel, and then the first gear, the gear should spin free when rotated clockwise. Does it?"
Yes indeed. It's funny, because a manual I checked out has kind of contradictory instructions, but I think it was just a poor choice of words on the copywriter's part.
"The manual states to first install the freewheel, then use the tool to hold the springs.......don't know if that makes a difference"
I was dubious of this, but I re-installed it regardless to make sure. Seems to be no difference.
"Make sure its not the wheel instead of the motor causing lock up."
It's definitely not the wheel itself. Reasonable question though.
So what is happening is...when I fasten the clutch housing or whatever it's called (it's in my left hand in the top pic), it prevents the clutch bell from turning; this is not because the inner rubber it being pressed against, but the brim of the bell is being pressed. I see it happening, but I can't wrap my head around it. What the heck is going on?
  Garelli NOI 2 speed - Wheel not turning backwardsTopic by: Daniel M Daniel M 10/26/13 03:24PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/26/13 04:01PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Harry Crank Harry Crank 10/26/13 07:36PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 10/29/13 10:46PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/30/13 02:14PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 10/30/13 02:59PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/17/13 10:22PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Brian Solex Brian Solex 10/30/13 06:27PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: micah aguas micah aguas 11/02/13 06:14PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/20/13 09:34PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 11/20/13 09:45PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/20/13 11:18PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel M Daniel M 11/21/13 09:16PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/21/13 11:54PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Declan g Declan g 11/21/13 11:55PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/02/19 01:25PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/26/19 12:11AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Sean Colvin Sean Colvin 07/28/19 11:28AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Still Ill Still Ill 09/04/19 09:55AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 12:51PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Daniel '' Daniel '' 04/08/19 03:17PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 04:47PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Stephen Simmons Stephen Simmons 04/08/19 08:07PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 04/08/19 09:02PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Stephen Simmons Stephen Simmons 04/08/19 09:18PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 07/25/19 01:23PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Barry (Bob) Brown Barry (Bob) Brown 07/31/19 08:23PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Josh G Josh G 07/29/19 02:37PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: Sean Colvin Sean Colvin 07/31/19 09:51AM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/31/19 04:02PM
  Re: Garelli NOI 2 speed - Wheel not turning backwardsRe: live ɘvil live ɘvil 07/31/19 08:06PM
