Another tire change thread
Brad William /
I've been away for a while so this might be old hat.
Discalaimer.... five bottles into a six pack of Lagunitas Little Sumpin'.
The spring decision to swap rear and front tires to get some more miles out of 'em has come to September.
I finally get the chance to try a suggestion from a thread at advrider.com
http://www.advrider.com/forums/showthread.php?t=299597
He uses ratchet straps. Other threads on this technique suggest zip ties. I just used packing tape. Good and strong and perfectly disposable.
Wrap the tire with the tube inside. Make sure that the BEADS TOUCH and that the tube is protected behind them. Next time I'll stretch the tube out better so that it's not so hard to tuck behind the beads.
A five gallon plastic bucket is a fine support for the wheel.
I put a bit of Armor All along the rim and the tire to assist sliding on. Put the stem into the wheel and loosely thread a nut on it to keep in place. After discovering how damn easy this was next time I'll skip the armor all.
It just went on like a tupperware lid!
I couldn't stop smiling!
I've wasted so much money and anger on pinched tubes and slipping tire irons that when this thing slid on I was actually giddy. Putting the tube stem into the hole and holding in place with a nut accomplishes tire mounting "101" by situating the tube (and in this case with the tire held together with tape, both beads) into the deepest part of the rim 180 degrees from where you begin sliding the tire onto the rim.
Afterward, instead of loosening ratchet straps or trying to reclaim zip ties by defeating the catch inside of them (or just tossing them) It took me 30 seconds to go around the tape with this....
and throw the scrap tape in the trash.
  Another tire change threadTopic by: Brad William Brad William 09/15/13 01:45AM
  Re: Another tire change threadRe: Saabsonettguy . Saabsonettguy . 09/15/13 04:10AM
  Re: Another tire change threadRe: OG vandal OG vandal 09/15/13 08:15AM
  Re: Another tire change threadRe: Marc Friedman Marc Friedman 03/23/14 03:37PM
  Re: Another tire change threadRe: Tptwo Tptwotwo Tptwo Tptwotwo 09/15/13 05:17PM
  Re: Another tire change threadRe: Rebel Moby Rebel Moby 09/15/13 11:29PM
  Re: Another tire change threadRe: Chas Gantz Chas Gantz 09/16/13 06:16AM
  Re: Another tire change threadRe: Matt Madden Matt Madden 09/16/13 10:39AM
  Re: Another tire change threadRe: Elliot Craig Elliot Craig 03/23/14 09:15PM
  Re: Another tire change threadRe: mit mortso mit mortso 03/23/14 11:55PM
  Re: Another tire change threadRe: Marc Friedman Marc Friedman 03/24/14 03:05AM
  Re: Another tire change threadRe: Glenn Kuehn Glenn Kuehn 03/24/14 02:55AM
  Re: Another tire change threadRe: Rebel Moby Rebel Moby 03/24/14 12:42PM
  Re: Another tire change threadRe: Marc Friedman Marc Friedman 03/24/14 12:59PM
  Re: Another tire change threadRe: Emerica   Emerica   03/24/14 03:11PM
  Re: Another tire change threadRe: Rebel Moby Rebel Moby 03/24/14 03:22PM
  Re: Another tire change threadRe: Emerica   Emerica   03/24/14 03:50PM
  Re: Another tire change threadRe: matt boda1nz matt boda1nz 07/26/14 10:17AM
  Re: Another tire change threadRe: Marc Friedman Marc Friedman 07/26/14 12:05PM
  Re: Another tire change threadRe: Gordon Freeman Gordon Freeman 08/23/14 06:08PM
  Re: Another tire change threadRe: Marc Friedman Marc Friedman 08/23/14 06:31PM
  Re: Another tire change threadRe: matt boda1nz matt boda1nz 07/22/14 03:53PM
  Re: Another tire change threadRe: Marc Friedman Marc Friedman 07/24/14 01:21AM
  Re: Another tire change threadRe: matt boda1nz matt boda1nz 07/22/14 05:04PM
  Re: Another tire change threadRe: matt boda1nz matt boda1nz 07/22/14 10:19PM
  Re: Another tire change threadRe: Steve Clark Steve Clark 07/24/14 07:08AM
  Re: Another tire change threadRe: matt boda1nz matt boda1nz 07/26/14 12:08PM
  Re: Another tire change threadRe: Marc Friedman Marc Friedman 07/26/14 12:56PM
  Re: Another tire change threadRe: matt boda1nz matt boda1nz 07/26/14 01:33PM
  Re: Another tire change threadRe: Maciek Dub Maciek Dub 07/26/14 05:10PM
  Re: Another tire change threadRe: Maciek Dub Maciek Dub 07/26/14 06:36PM
  Re: Another tire change threadRe: matt boda1nz matt boda1nz 07/26/14 06:31PM
  Re: Another tire change threadRe: matt boda1nz matt boda1nz 07/26/14 06:58PM
  Re: Another tire change threadRe: Marc Friedman Marc Friedman 07/26/14 07:18PM
