Which carburetor replacement for 1978 Puch Maxi?
Someone recommend some compatible carburetor makes and models for a '78 Puch Maxi? Thank you.
Re: Which carburetor replacement for 1978 Puch Maxi?
simon thokaar /
you can get the same bing or just the parts for the original bing from treatland. Or you could slap just about any carb that will fit your intake on there. Ive had the best luck with Dellortos and Mikunis.. Bings and Encarwis always piss me off..
Dmitry K. /
I also had good luck with Dellortos. 1977 sells all sorts of Dellortos. I emailed them, but still no response.
Which Dellorto model for a 1978 Puch Maxi.
https://www.treatland.tv/puch-moped-parts-s/26.htm?searching=Y&sort=5&cat=26&f-party time=133&f-carburetors, intakes, reeds, air filters, jets=54&show=50
this all at the carb intake kits they have. treats is awesome and fast shipping.
simon thokaar /
> no response.
depends on your intake.. probably a 16.14 SHA. My only puch is e50 kickstart for magnum x.. its carb intake is like 22mm so not sure what size yer maxi has.. they they are stock 14mm tho.
Dmitry K. /
Dellorto SHA 15.15 doesn't seem to have a primer. Don't stock Puch carbs have primers?
you know why they're called bings?
it's the sound they make as they hit the garbage can
Re: Which carburetor replacement for 1978 Puch Maxi? 1.5 H.P.
Besides a bing what carb is recommended ?
Not bumping an eight year old thread is recommended. 😆
If you don't want to use a bing, the sha kit linked to in this very thread works well.
Dirty30 Dillon /
I recommend reading any of the 100,000 threads on the subject and making an informed decision.
