I bought a 1978 Honda PA50II and I can not get the thing running.
New:
Chain
Ignition switch
Spark plug
I pedal the hell out of it with the ignition and the kill switch on but nothing.
Any ideas on what could be the problem?
Thanks
New:
Chain
Ignition switch
Spark plug
Thanks
First off before you get any serious responses from here you need to check for spark, fuel and compression.
I would start with making sure you have spark since you put in a new ignition by holding the spark plug against the head while turning over the motor.
what size chain?
1/2 by 1/8
I cleaned the points and check the spark and still nothing. But when I was messing around I saw that a black and white wire coming from the ignition coil wasn't hooked up to anything and I can't figure out where it goes to so maybe that is the problem.
Ya, your going to want to hook that up. The black/white wire hooks up to black/white from the silicon rectifier. The black/yellow hooks up to the black wire with the yellow tape from the stator.
Is the silicone rectifier the small black box with three wires coming out of it?
Yes.
