Re: How NOT to put your transmission back together (Suzuki FA50)
Old Greg Motorcityriot /
i doubt if you will find at the hard ware store ,because those (washers)are actually shims yuor best bet is to get them from dealer or ebay or you can run without it youll just have a little more play on that shaft because if i remember correctly that shim is only about .003 or .004 thick
