Re: Suzuki FA50 strange noise..
Old Greg Motorcityriot /
they sound like any other 2 stroke they are a little noisy in the trans but they are gear and chain driven....it might be worth while to pull the side cover off and inspect trans for any signs of a bad bearing or gear while the cover is off you can also spin the motor by hand as the clutch will be exposed just remove plug so the motor will spin free you can then see if it is the motor itself making the noise
