Re: Suzuki FA50 strange noise..
Old Greg Motorcityriot /
how long had it been sitting your carb may need cleaning ..as for your noise listen in the transmission area while spinning back tire by hand see if you can hear the noise..if you cant hear anything its probably in motor..also check oil in trans there is a bolt with an aluminum washer in it that is how check oil level in trans
