V1 finally runs!... Kinda.
I've been fixing my friends motron. And the main problem was timing. I cleaned and reset point gap, and re timed it. Points start to open at the first line. are about as wide as a piece of spark plug box at second. It had an NGK plug that was giving a blue spark, like every 4 turns. I would get pats and sputters. but no liftoff. I put in an autolight plug and it gave an orange spark, but it hit every time. so I hooked it all up and first kick she fired right up.
So I took her for a little test ride and as soon as I hit about 25mph. it would spit sputter and die. (the descending vrrrrrrrrrrrrmmmmmm sound) but if I let off it would kick back on and idle while rolling. Is this because of the weak spark? timing off a cunt hair?
Side notes:
16:16 SHA with puch side intake.
74 jet, stock air cover that comes on carb.
60cc Olympia kit.
Proma pipe.
any thoughts appreciated.
-N
Re: V1 finally runs!... Kinda.
Probably Fred /
If you don't time it correctly that kit will be toast
I think It's an air leak.. just need to find it.
Nope past air leak tests.
only found one small one where intake meets carb. didn't even shut it off. just lowered idle a bit for a few seconds.
Where is your feeler gauges? On the minarelli v1's I set them @.014's. I think you are way to rich with a 74jet. It is only 43mm cylinder kit. Try a 70 and lower or go to a 76,78,80.. and see if it rich-ens.
I spoke to angel, and I figured it out. My point gap was too small. at high rpm it was not open large enough to spark. moved the points over like 1 or 2 degrees to the right and now it runs fine. I actually had a 72 in it not a 74, but before I changed the timing I went down to a 70. so that's what it has in now. it seems a little hot. I got no 4 stroke on take off or top, so I'm going to take it up until i four stroke on top. then go down one.
Since it is a 43mm bore=60cc kit. I would set it at 21 degree btdc then retard the stator completely.
first line is 23 degrees correct? i don't think it is stator is fully retarded but it is on the retarded side.
