Kreidler 1978 Electrical and Sputter
Olivia Collison /
The headlight and horns on my 1978 Kreidler won't work. I've changed the bulb and everything's hooked up right. Anyone have an idea as to why they still won't work?
The moped itself sputters and slows to a near halt after less than a mile of riding. I have a feeling it just overheats, but anyone have any other ideas?
Re: Kreidler 1978 Electrical and Sputter
overheating eh? a common cause of sputtering to a halt is a bad condenser, try wiring in an external one. If the condenser's bad it'll need to cool off before running again, and there'll be no spark when it dies so check for that\
the other common cause is poor fuel flow and the bike draining the carb bowl faster than it's filling. that's easy to check so give it a look-see
as for the headlight and horns, check that you've got power coming out of the stator on the lighting wire with everything else disconnected. it's probably either the coil's shot or more likely the wire's grounding out somewhere. if you got a multimeter or continuity tester just isolate the segments of wire to track down the faulty ground.
