Re: Vespa Grande not starting. dripping fuel.
Marc Friedman /
You are sure there is blue spark from the plug you are using? I guess your float level valve could be stuck open and gas is pouring into the carb body by gravity. If that were the case you would need a tornado directly passing through the Venturi to compensate, that's my guess.
