not starting
Derick Soland /
need help with hobbit, I have great spark and timing is perfect. I am getting fuel into the cylinder, it was running awesome and the only thing i changed on my PHBG is the main jet. Compression is good, it should be starting and running but its not kicking over, very confused any ideas?
Re: not starting
If its not kicking over then your engine is seized. Is it two stroke? Did you not run it with oil?
Re: not starting
Derick Soland /
no it moves very freely
Re: not starting
from what size jet to what? i know when i changed the jet on my mikuni from 70 to 90 (thought it was the 80 damn tiny numbers) my ped wouldn't start. Also, when i changed back to the 70 it ran fine. Then the jet rattled off because i apparently didn't tighen it enough i died instantly and would not restart. Sucked when you're a mile from your tools. Fuck pedaling a moped. 150 lbs of shitty crank. fun times. dont pull a Rambo.
Re: not starting
mark brezovsky /
not starting. bogging when throttling different speeds. took carb off cleaned good put back together now not starting. fuel is in carb but not in cyl. it ran before removing carb
Re: not starting
Andrew Kotcher /
something is plugged up,
