moby motor mounts
The book says to note the placement of the shims and return them to the same place. How do I tell if the previous owner did this correctly? If he didn't how do i get it right?
Re: moby motor mounts
once youve got the engine hung, make sure the belt is riding between the variator and the pulley without being at an angle. It should be perpendicular to the center axis of both the engine crank and the pedal crank.
Thank you that is what I needed to know. I have found with most things I have bought used some-one has done something half-assed.
