garelli too much gas & head light
i have way to much gas going to my carb someone said to ajust the carb pin any help on how to do that? and what is the brightest bulb for a 1976 Garelli eureka flex. and how do i change it. thanks i dont want to break anything and everyone here seems to be a lot of help.
Re: garelli too much gas & head light
Emil Kniemel /
hmm.. maybe you have not been here long enough.
clearly not ? you just commented on my post. pointless dick move on someone who just needs help.
Headlight bulb:
6 Volt 21 Watt
Instructions for removing/installing:
http://www.mopedriders.org/html/manuals/garelli/csm/garellism094.jpg
Instructions for removing and disassembling carb to access the float and float needle:
http://www.mopedriders.org/html/manuals/garelli/csm/garellism083.jpg
http://www.mopedriders.org/html/manuals/garelli/csm/garellism084.jpg
If the float has gas inside, you will need to replace it. Inspect the float needle to see if it is in good condition and seats correctly to shut off the fuel flow.
thank you you have been a big help i will check it tommorow. and replace the bulb as well
26 watts available if you add up all the bulbs, stick with the stock wattage.
put a critical eye on the float needle, if it's anything but a nice cone, it's toast, hershey kiss is what they end up looking like when worn.
float tang is plastic, doubt you can adjust it.
title of the thread made me think this:
