Re: Derbi flat reed just stopped
Charles Nalbantan /
Had all the same symptoms last week wiith my '89 Derbi of many years. Here's what I did.. Now she runs like new and starts right up! Removed and cleaned the fuel tank. Removed and replaced the petcock (filter on it sits inside the tank and was pretty gunked and there was corrosion inside...probably could have used the same one after taking it apart and cleaning it, however) removed, took apart and cleaned the carb (loaded with gunk). Replaced the in-line fuel filter (be sure it's set in the right direction...not all replacements are marked as such) I use the clear view type with the white trans screen i find best for 2cycles...and you can see) If the flow direction isn't marked, can't hurt trying it the other way).
Before all this it was running... Then just stopped..having all your exact symptoms. Like you, Starting fluid only allowed me to know there was a good spark... So I just worked back from there covering all bases with fuel flow. Like Richard S says..spark + fuel = combustion. Let me know if I can help with any questions. Best of luck.
  Derbi flat reed just stoppedTopic by: Gee Buda Gee Buda 08/15/12 05:56PM
  Re: Derbi flat reed just stoppedRe: Ryan N. Ryan N. 08/15/12 06:04PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/15/12 08:13PM
  Re: Derbi flat reed just stoppedRe: Ryan N. Ryan N. 08/15/12 08:56PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/16/12 03:58PM
  Re: Derbi flat reed just stoppedRe: Ryan N. Ryan N. 08/16/12 05:30PM
  Re: Derbi flat reed just stoppedRe: Richard Schwartz Richard Schwartz 08/16/12 06:51PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/16/12 07:31PM
  Re: Derbi flat reed just stoppedRe: Richard Schwartz Richard Schwartz 08/16/12 07:44PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/16/12 08:12PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/16/12 07:29PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/18/12 04:44PM
  Re: Derbi flat reed just stoppedRe: Charles Nalbantan Charles Nalbantan 08/22/12 12:23PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/22/12 07:12PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/20/12 06:25PM
  Re: Derbi flat reed just stoppedRe: Ryan N. Ryan N. 08/22/12 12:26PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/22/12 03:14PM
  Re: Derbi flat reed just stoppedRe: Jake P Jake P 08/22/12 02:50PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/22/12 03:18PM
  Re: Derbi flat reed just stoppedRe: Charles Nalbantan Charles Nalbantan 08/29/12 12:13PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/29/12 04:27PM
  Re: Derbi flat reed just stoppedRe: Deadped Ryan Deadped Ryan 08/29/12 05:40PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/30/12 07:16AM
  Re: Derbi flat reed just stoppedRe: Mikebeez Blkblk Mikebeez Blkblk 08/29/12 11:08PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/30/12 07:17AM
  Re: Derbi flat reed just stoppedRe: Deadped Ryan Deadped Ryan 08/30/12 09:23AM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 08/30/12 12:04PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 09/03/12 11:29AM
  Re: Derbi flat reed just stoppedRe: Deadped Ryan Deadped Ryan 09/03/12 01:02PM
  Re: Derbi flat reed just stoppedRe: Gee Buda Gee Buda 09/03/12 01:54PM
  Re: Derbi flat reed just stoppedRe: Mo Peds Mo Peds 09/03/12 04:00PM
