Hobbit issues: SHA/phbg carb
100:1 amsoil saber
b7hs ngk plugs
pa50i bottom-end
proma exhaust
pa50ii cylinder #2
stock head
pa50ii reeds/block new!
pa50ii intake with 19mm tomos header for spigot mount carbs
new inline condenser, removed old
cleaned and set points to 0.35mm
gapped spark plug to 0.6mm and 0.3mm, no difference in performance
fat blue spark
black wire to coil,green grounded,red nothing,yellow lights
no air leaks and tons of compression
plugs are black
I have tried both a 14.12 sha and a 19 phbg clone with similar results. It will idle, but not move past 1/4 throttle without bogging. sounds like a lean bog.
14.12 sha i have converted to a spigot mount. I have the exact same setup on another hobbit that runs a 69 jet perfectly. i have tried jets from 52 through 82, no dice. i have tried multiple airfilters, still bogs out once i give it a little throttle.
19phbg uses a w7 needle and stock idle/pilot. I have had some success with a 69-72 main jets, but only at idle. I know the main jets don't even affect the idle with a phbg, so it's the idle jet. I have tried the needle at every notch, same thing happens when i give it gas...it just dies...bogs out.
any tips or ideas? (edited)
Re: Hobbit issues: SHA/phbg carb
.35mm points seems really large!
[Radium City] kyle k $ /
no ur thinking in inches .35 mm is .014in
black plug =rich so probably not a lean bog . Try choking the carb, a little at a time, with fingers, and see if it's better or worse(rich or lean). Is your timing good ? check for airleaks?
i know it's not electrical (replaced points and condenser) - although it could be the coil...has bright blue ass spark though.
guess it could be the seals? i have tried 69,63,61, & 59 jets in the 14.12 sha with same results...it will idle great, but then do nothing when given gas. any ideas?
Solved. Stuck reeds. Thanks everyone
