sputtering and backfire
Michael Bojanowski /
I took the moped out for a cruise today went about a mile and it was running good, then it started to sputter alittle and lightly backfiring, it didn't have much power I got it home but it stalled right in my driveway, now it order for me to start it I got to give it full throttle, but then it only runs for a few seconds then stalls. I noticed smoke coming from where the exhaust pips is smaller then gets fatter, I think there is a gasket there, could my exhaust be clogged up??? The carb. is clean, is it possible the float was sticking and I was getting too much gas, the float sticks now and then. Thanks! Oh yeah I have a 1977 Pinto moped.
Re: sputtering and backfire
John Warren IhazJawas /
clean out the exhaust i had the same issue then try to run it
Any body got any other ideas? Thanks!
Clean out the pecock as well. Get an inline fuel filter too.
Remove the exhause, clean the exhause port with a popsicle stick.
Dump some ovencleaner into the exhause pipe and leave it sit for however long the can says for a cold oven and then hose it out.
Dont get the ovencleaner onto anything aluminium or it could be a sad day. (edited)
I took the whole exhaust apart, do I spray the oven cleaner in the chrome exhaust part or the baffle that I took out of the exhaust, it looks like the chrome exhaust part is pretty clean inside, its hard to tell how dirty the baffle is, I can't see inside of it.
Do I spray the oven cleaner inside and all over the baffle?
Yes. That's what I do. But, I use engine degreaser and spray it all up in there, let it soak for a few hours then rinse with a hose and do it all over again a few times.
There's the camp fire/torch trick, but I've never tried it.
Yes - oven cleaner is designed to clean off baked on grease and oil in a oven that has been heated up lots of time so yes it works better then engine cleaner.
Backfiring sounds like a timing issue.
Both.
