Re: removing flywheel with a piston stop harmful?
Rebel Moby /
Hold the flywheel not use a piston stop which will flat spot the bearings... unless you are removing the flywheel to open the cases to swap out crank and bearings then just keep in mind the crown of the piston might have a peened spot in the center from the piston stop.
