Re: Two Puch Maxis won't idle
Colin Griffin /
Returning to the old problem...I didn't have much time for the last month to work on the bikes, but I finally went through a number of the suggestions I got on here the other day. I have not checked/done the following, and still no idle:
-Checked fuel flow both at the petcock and at the carb itself (took the bowl off and it flowed steadily - stopped when I pushed the float up)
-Tried all of the needle clip settings.
-Tried jets from 64-70. Seems to run best around 68 or 70 at WOT, but still won't idle. Would try higher if anyone thinks it would help, but I'd have to order them.
-Cleaned the carb thoroughly.
-Sealed a couple air leaks.
-Did the slide mod a few people recommended
-New Spark plug
-Checked compression
-Checked exhaust for blockages
After all this it still runs fine when moving, it just won't idle. When started, if I just let it sit there, it will run fine for about three minutes or so until it warms up, then it starts to struggle a little, and within a minute will stall. When riding it, if I keep the throttle open a bit at stop lights I can keep it running, but unless I do this also while braking, it will stall as it decelerates. Also, if I don't hold the throttle open enough and the idle gets too low, it takes forever to pick back up. I open the throttle all the way and it struggles for a few seconds before kicking back in. If anyone has any other ideas of what I could try, I'd greatly appreciate it!
