A35 rebuild
Tal Reznikov /
Im rebuilding my a35. heres what i have so far
from treats
--2 of : 6203 C3 crankshaft bearing for puch e50 + peugeot + derbi + garelli + tomos + solex
--derbi flatreed & piston port + morini m1/m01 pedal crank seal - 16 x 24 x 5
--moped black headlight grill
--2 of: puch ZA50 + tomos A55 A35 A3 + minarelli V1 + morini - crankshaft seal - 17 x 35 x 7
--tomos A3 A35 A55 engine seal set
--tomos A35 main shaft seal - 35 x 47 x 7
--tomos A35 moped TOP racing crankshaft
--universal tomos throttle cable
--tomos A35 A55 clutch cover gasket
--tomos A35 A55 engine case gasket
--tomos moped 70cc high compression head
--dellorto SHA 15.15 carburetor with lever choke - 1.5 shim for tomos
from 1977
--Tomos A35 70cc 77 Race Kit
--Tomos Cylinder Head Stud ProPack
--Peugeot Tomos Puch 77 Race Reed Block
--Visu Inline Fuel Filter
--70cc Puch Head Gasket
--Universal Mirror -Blue X2
--Blue Dot Chrome Grips----- these where out of stock so they gave me
https://www.1977mopeds.com/product/3055/Pink-Knurled-Lined-Grips/
but in blue (they are for extra speed, hehe)
--EMGO Dellorto SHA Air Filter
--Dellorto 5mm Jetset -60's Edition
--Dellorto 5mm Jetset -70's Edition
--Dellorto 5mm Jetset -80's Edition
do i need anything else? other than a bunch of time and effort?
also, is their a step by step of how to do an a35 rebuild?
thanks
Tal R. (edited)
Re: A35 rebuild
Tal Reznikov /
bump
Re: A35 rebuild
I suppose everything you have listed will work, although not everything listed would be my first choice.
I'd add the following parts from treatland.
puch & tomos black metal lined exhaust gasket - quality!
I'd add the following parts from your local bearing supplier. These go inside the main gear and have the seal that prevents from leaking all over the place.
Needle bearing SCE 109P
Needle Bearing SCE 108
You didn't list an exhaust, buy you might already have one. You didn't mention an intake, which would be nice to get the full effect of the 15mm carburetor.
Re: A35 rebuild
Tal Reznikov /
Oh, i already have a tecno circuit
and im using stock intake
