where can i get a carbuerator for a 1977 batavus
Makayne Oriellis /
i have a moped 1977 and i need to replace the carbuerator but i dont have an idea of where to look for this item also how much is it in a round about figure,
if any of you out there may have an idea please feel free to send me that link
Re: where can i get a carbuerator for a 1977 batavus
STOCK Its a Encarwi which are shitty carb's. you can buy one probably from mopedjunkyard or buy/sell forum here
you can also replace it with the vespa style thinner Sellorto SHA carb's or their clones. this would probably be cheaper or the same in price for a new better carb vs. getting a shitty old crappy encarwi, but you may have to make or adjust a shim to fit it properly. cool.
Go with one of these new MLM intake (when 77 gets more back in stock) and strap an Dellotro SHA carb onto the bike.
MLM 15mm SHA intake
The SHA is the best thing (so far) that ever happened to my girl friends Bat.
If you get a 13.13 it will bolt right on or go the 14.12 route and get the MLM intake.
-Aron
i have a cheap vespa ob'd 11.11 vespa sha lever choke that will bolt right on. also have a cheap standard 12.12 sha w cable choke that give the same input as a 14.12 if you are swapping intakes.
i have the stock Encarwi A87 carb.
missing the choke plate but otherwise will bolt up easily
with no mods.
$25.00 shipped to you
get this while you search for a Dellorto Vespa carb or a
SHA
guaranteed to bolt right up.
i also have the stock airbox, bail wire, filter, tube
for another $25.00............these always get lost and broken
and are hard to find
why mess with the weird stuff..........get an original Encarwi
Makayne Oriellis /
WHERE IS THE CHOKE PLATE IF I MAY ASK
sorry for the caps
